Age range: 11-14 | 14-16
Duration: 30-59 mins
  • Engineering
Understanding aerodynamics
Making and testing an aerofoil
This is one of a set of resources produced in conjunction with the engineering company Arconic. The resources are designed to support teaching of key engineering concepts at both key stage 3 and key stage 4, including the new GCSE in Engineering. This resource focusses on understanding aerodynamics and making a simple aerofoil.
Understanding aerodynamics is key to understanding flight. Aerofoils are designed to allow aircraft to fly. The design of these is crucial to minimise drag and increase lift.
In this activity, learners will make and test a simple design for an aerofoil. They will learn about the terms lift, drag and thrust and how these apply to aircraft. It will build knowledge of aerodynamics theory and how this can be applied.
This could be used as a one-off main lesson activity, as an introductory lesson to a wider unit of work focussing on aerodynamics or as part of a scheme on aircraft design using all of the resources developed in association with Arconic. It could also be used to support the existing IET Faraday resources ‘Speedy boats’ and ‘Wind tunnel testing’.
Remember, it's all free!...and registration is free too!
335
Available downloads
To download any of the resources on this page please login or register
Activity
Activity overview
Understanding aerodynamics activity description, teachers' notes and curriculum links.
Handout
Handout
Making an aerofoil handout
Presentation
Presentation
Teacher presentation making and testing an aerofoil
